need help building motor for my c-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2011, 12:17 PM
ok i have a 82 c-10 just a play toy has a 305 with a t-350 now i want to build somethen wild that will scary the heck out of anyone rideing with me but on pump gas.... any ideas.. my budget well it will be a build as you go thing....
Old 01-17-2011, 12:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Use the search function here, search 305 build, 350 build, etc, there's hundreds of engine combinations here.
Old 01-17-2011, 02:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by kennyhammond
i want to build somethen wild that will scary the heck out of anyone rideing with me...
I suggest 14" rotors w/4-piston calipers up front and a pair of 12" rotors x 2-pistons in the rear for brakes.
I have been WAY more scared stopping than I ever have taking off hard.
Old 01-17-2011, 02:58 PM
lol yeah i am doing a rear brake conversion to disk.. but i dont realy know anything about matching parts up on the motor to make a god combo.. i searched and found alot of jiberish
Old 01-17-2011, 03:05 PM
kennyhammond,
I don't think HE is into engines and things. These things are left to us.
Sorry I had to
Scholman
Retired
Old 01-17-2011, 03:10 PM
Leoman's Avatar
Year One, of all places, has a dyno'd 400+hp 350 crate motor for $2989! You still need valve covers, carb, distributor etc. It's Vortec-based. The part that says to get a melonized distributor gear suggests to me that it has a hydraulic roller cam. The price is almost too good to be true, but I don't think they'd jeopardize their name on junk. Not a complete monster, but definitely scarier than the 305!
Old 01-17-2011, 03:15 PM
o0k the other question i have is i have a (around 98 or so ) chevy 350 vortec motor in grandpas old truck... would that be a good motor to start with and rebuild?
Old 01-17-2011, 03:26 PM
Leoman's Avatar
Sure, if the cylinders and rotating assembly are still ok. But tossing a hot cam or even just headers and a new intake/carb onto an old veteran engine isn't always a good idea. I think you'd end up spending as much rebuilding it as you would for the crate motor, plus you wouldn't have to worry about the new engine having hidden surprises. You can always void your warranty on the new one and build it up (I'd give it a try as is first). Read up on it via the web.
Old 01-17-2011, 03:31 PM
put a 6-71 blower on the 305 drop the compression 9.1 750 carb headers rebuild the t 350 trans add a shift kit and a 2500 stall with 3.42 gears and cry when you hit the cas
Old 01-17-2011, 03:35 PM
yeah i will take it out and start from the bottom up... bit that's what i am asking what combos of parts would be good together to build 450HP on pump gas? i newness everything from the pistons to the distributer....i know i am asking rookie questions but i am 23 and want to build it not buy it thanks for the help
Old 01-17-2011, 04:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moving to the Basic forum.
Old 01-17-2011, 04:16 PM
so any input...
Old 01-17-2011, 06:28 PM
spinn's Avatar
Starting with your 305. My project started like this.
Performer cam
Vortec heads Performer intake
3.73 gear
about to start exhaust with installing ,headers when one system fits.
The cam gave a little more power everwhere . Starting from the RPM it foot brakes from , made a nice revy difference. Sounds like a stampede of ponys.
The Vortec heads kicked all butt. Made the single biggest difference in power, but the original 305 heads were poor. A couple seals leaking did not help either. The vortec Performer intake offered nothing noticeable from the original. It still had a 2.73 gear.
The gear change to 3.73 gear with 28" 235/70/15 tire was welcome. The truck became lighter. Powerful footbrake smoke shows a plenty. With a 1600 footbrake stall, the truck torqued out of the hole like a bat out of hell.
My goals were to get the straight line acceleration of a mid 80's vette. C=D gave the 85 C10 a 17.7 in the 1/4. Some iPhone gizmo app claims it is now capable of 15.5 at 88mph. A LT1 auto vette when about 14.4-14.6. More work to do...
building a new motor 1978 corvette Engine 4 08-05-2010 11:52 AM
?? on building a motor. 1972bigblockchev Engine 0 01-03-2008 05:32 PM
Building a 671 SBC Motor TheAmericanDream Hotrodding Basics 5 06-13-2007 09:50 PM
building a hot motor mgm Hotrodders' Lounge 4 03-14-2003 08:15 PM
new to da motor building game sidtrippinghrd Engine 3 08-25-2002 02:21 PM
