nEED HELP WITH CAM SELECTION - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2005, 10:07 AM
I am building a 383 stroker in my 69 camaro.
My car is a show quality weekend driver. Do not race it at the track but I do drive it hard on the street occasionally. Need good vacuum for power brakes and all othee accesories - do not want a vacuum canister.
This is my build:
350 block 40 over
Edelbrock RPM Air Gap
AFR 195 cc heads
10.5:1 compression
Hooker 1 3/4" super comps
Muncie m20 4 spd
4:10 rear
26" tall tire
all in a stock camaro.
whould like cam to come in around 2,500 rpms - 6,000. I like a little lope to it.
give me your suggestions for duration, lift and lsa
Also Hydro roller or solid flat tappet?
Old 03-14-2005, 11:01 AM
USA1's Avatar
How about this. http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNum ber=113532&lvl=2&prt=5
Old 03-14-2005, 12:06 PM
firestone's Avatar
http://teamrfc.gospelcom.net
If you have the money to go with a roller, do it. As far as a hydraulic roller goes, I would look at the 268HR (230 230 @.050 .560 .560 lift 2500-6000 RPM) It says limited vacuum in the comp cams catalog, but I think it will be fine. I have a friend with a 383 and a cam with 237 241 @.050 duration with .530 .530 lift, and his car is fine. The brakes are a little soft, but nothing unbearable. As far as a hydraulic flat tappet, I would look at the 280H (230 230 @.050 .480 .480 lift 2000-6000 RPM) this cam would work really well with a set of 1.6 rockers to get the lift up to around .510 and get a little more flow out of the AFR 195's. Both cams would have good torque, and stop around 5800-6000 RPM.
Adam
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
The cam mistake is running, well, kinda! Jmark Engine 12 12-31-2003 12:49 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
Cam Selection...Please help! 1BDMNTY Engine 22 03-28-2003 01:11 PM
HELP cam, intake and carb selection? sniper4570 Engine 5 01-15-2002 08:16 PM
