need help with camaro clip for '48 pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2011, 12:57 PM
Looking for tech info on how to graft a camaro clip to a '48 pontiac chassis. it's a silverstreak. thanks.
Old 01-30-2011, 04:49 PM
low budget rodder's Avatar
As you know, 46-48 Pontiac, Oldsmobile, Buick, etc... are still pre-war design... and basically the same. I did a front Subframe for my 47 Oldsmobile model 76. I put text with the photos so you can follow along.
The subframe that fits perfect.... 79-82 old cutlass, Chevy Malibu, etc. The frames are perfect and when they blend together, you can't tell where one ends and another begins. They sell various height spindles, brakes, rotors, pads, ball joints, etc that is inexpensive and can be found anywhere.
Take a look and judge for yourself.
best of luck,
~Joe
ID:	52083   Click image for larger version
ID:	52084   Click image for larger version
ID:	52085   Click image for larger version
ID:	52086   Click image for larger version
Old 01-30-2011, 09:31 PM
machinist & fabricator
i opted for a 73 cadi clip in my 42 pontiac, bigger brakes, and the clip was free.
wheel base and ride height...... cut, weld, reinforce... DONE
Old 01-31-2011, 01:35 PM
CALI4N1A's Avatar
hot389, any pics of the process? I'm debating on which way to update the existing IFS on my '41. Either find arms from a '58 or go with a clip?
Old 01-31-2011, 04:50 PM
no man, i was a tard and blasted it out in about 2 weeks without taking pics....
go with a clip! the upper control arms/ shock absorbers are wayyyy outta date!
38 Pontiac front strut clip install Quarter Flash Suspension - Brakes - Steering 2 10-01-2009 08:58 PM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 01:05 PM
Camaro front clip/ Yr???? Chevy535 Suspension - Brakes - Steering 3 07-21-2006 11:38 AM
50 pontiac coupe want to use a s10 front clip and rear will these work thanks JOHNNY M BROWN Suspension - Brakes - Steering 5 11-27-2004 08:12 PM
1951 Pontiac Front Clip?? Custom_Rods Suspension - Brakes - Steering 3 04-29-2004 07:11 PM
