Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help..cant get diplomat hood open
Old 05-11-2006, 05:41 AM
baddbob baddbob is offline
It may be as simple as having some one lift up on the hood while you pull the release. Lube up that latch before you shut it down. Also adjust the hood bumpers if needed. If that doesn't work try taking the grille out for access, maybe you can see the latch bolts or striker bolts to remove.
