need help with casting numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2006, 03:36 PM
the casting numbers off the block areC90E-6015-C i just need to know what it is plz
Old 01-30-2006, 05:24 PM
Chopt 48's Avatar
Ford block? Their casting numbers usually are somewhat of a part number.
Ford experts?
Old 01-30-2006, 06:42 PM
Yea, that's a Ford casting number. The block is the third (fourth?) revision of a 1969 block. Someone else can tell you what the rest means.
Old 01-31-2006, 01:05 PM
aka Duke of URL
C90E-6015-C
1969 351W cylinder block (bare).
The suffix of a FORD PN does not always ascertain design development. It could also mean a different part introduced in the same year, front or rear, left or right or finish type.
Old 02-02-2006, 02:09 PM
thanks for al the help i did find out i have a 351 w
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Oldsmobile casting numbers? Kenny13z3 Engine 13 05-25-2009 11:30 AM
casting numbers stuartc Body - Exterior 2 01-30-2006 05:41 PM
Ford Axle Identification ( Casting Numbers ) Ozsuba Transmission - Rearend 1 01-01-2006 10:55 PM
casting numbers 47fordhotrod Engine 0 05-28-2002 12:30 PM
