need help changing out sterring collumn on a 1979 gmc high sierra half ton 4x4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2010, 04:18 PM
hi i have a 79 gmc sierra that the lock cylinder is stripped out and have to replace the collumn and i have an 80 gmc that is an automatic and the 79 has a auto in it but came with a 4spd in it from the factory and i need info on how to switch them out and make them work the collumn is coming outta the 80 and going into the 79 please help i really need this info
Old 10-10-2010, 06:51 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Are you asking to replace the manual trans column with the Automatic column??
If so---should bolt right in
If you still have a floor shift----just remove the column lever.
No Biggy
I have an AT tilt in my 4-spd 79
Old 10-10-2010, 07:46 PM
collumn
well the 79 came with a 4spd but the guy i bought it from put an auto in it with a floor shifter and he was using a screwdriver to start it i put a new lock cylinder in it but the internals inside the colum are shot so im just swapping colums out with my 80 gmc and it has a column auto shifter in it from the factory so i was just wondering if they were gonna be able to swap them out without changing major stuff around on it cuz the 80 gmc column has a good lock cylinder in it already
Old 10-10-2010, 08:53 PM
Bryan59EC's Avatar
It will work just fine.
You can even go do a bit of junkyarding and get the linkage and anchors to use the column shift.
I think I even have all that stuff on an 81 that is in my yard
Old 10-10-2010, 10:14 PM
collumn
well the linkages dont matter cuz the truck is being put back to a 4spd i was just wondering if there were gonna be any problems hooking them up or if anything had to be modified to make them fit
1989 GMC one Ton - 4x4 axle conversion? Chevy_force Transmission - Rearend 1 08-27-2008 12:42 AM
1979 silverado half ton with 350 small block HotSpringsGal Hotrodding Basics 3 10-05-2006 11:03 AM
87 gmc 1/2 ton 4x4 AT gmcmaniac Introduce Yourself 1 12-07-2004 11:51 AM
