Need Help choosing and auto tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 07:36 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
I have a 1991 gmc sierra 2wd pick up. I put a modified 350 in instead of the stock 305 tbi. I keep smoking the tranny out of the truck for some reason. It is a 700r4. I believe the motor has 350ish hp. I just cant figure it out. I want the overdrive tranny but this is going on the 3rd transmission.
Any Help will be appreciated
Thanks
Ed
Old 07-15-2012, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Ed
A proper built 700 trans would have no problems with that HP level you mention.
Who is building the trans for you? Experienced shop ?
Old 07-15-2012, 11:14 PM
Greg T's Avatar
www.krusinklassics.net
Thanks
Ed
You pulling gobs of weight with 2.73 gears?
Old 07-15-2012, 11:21 PM
pricesgarages's Avatar
are u carbed or efi if using aftermarket carb u need the correct linkage and brackets to make it work properly
Old 07-16-2012, 03:13 AM
400smb_s10's Avatar
Back Yard Junky :)
No one is building them they are just stock transmissions. and yes it is carberated but i have a floor shifter so i shift it manually. The rear gears are 3:73's and i dont use is for working its just my everyday driver.
Old 07-16-2012, 07:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The TV cable adjustment is uber critical and has to be correct!! If it isn't, bye-bye trans...
Check out the links, etc. here for more details on how and what to do.
Old 07-16-2012, 08:33 AM
I guarantee if it was a quality rebuild, and your driveline is all in alignment; that your TV cable is FUBAR and you need to correct its geometry or keep buying 700r4's...BTO is one source but there are others
Old 07-16-2012, 03:26 PM
400smb_s10's Avatar
Back Yard Junky :)
I just picked up a new one this morning. 72000 KMS for 250 bux. Do I still need to adjust the TV cable still?
Old 07-16-2012, 03:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Reread post #6...
Choosing an Auto Transport Company wretched ratchet Hotrodders' Lounge 15 08-08-2011 05:51 PM
91 s-10 auto tranny Prof. T. Soggmeyer Transmission - Rearend 5 04-22-2007 06:39 PM
3speed auto tranny? TonyMac Transmission - Rearend 3 01-09-2005 09:26 AM
help choosing tranny 64novaboy Transmission - Rearend 8 11-20-2004 06:41 AM
Auto/Manual tranny... muscarmad Transmission - Rearend 5 08-25-2004 01:14 PM
