Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help for choosing a cam
Old 08-22-2008, 07:38 PM
eric32 eric32 is offline
Go with a comp xtreme energy cam similar size or a comp magnum cam. You will get a little lopey idle but still get good vacuum. If all else fails get the comp thumpr flat tappet cam but the previous ones will give you better horsepower and torque. It will give you a nice choppy idle and not be too much problems. If you go with anything bigger expect some carb tunning headaches.
Eric
