Originally Posted by chevrolet327
ok my set up is 327 11-1 domed piston camel hump fully ported aftermarket rod
performer rpm intake manual transmission. the problem is the cam i have is a summit 1105 cam 224/234 duration and 465/488 lift the cam run very well but idle is like stock engine . im looking for cam with similar spec but very rough idle
can a put more agressive cam on this little 327
You could do it the cheap way,put a manual choke on it and pull it out a ways and it will sound choppy then push it in when you want it to run decent.
