ok my set up is 327 11-1 domed piston camel hump fully ported aftermarket rod
performer rpm intake manual transmission. the problem is the cam i have is a summit 1105 cam 224/234 duration and 465/488 lift the cam run very well but idle is like stock engine . im looking for cam with similar spec but very rough idle
can a put more agressive cam on this little 327
Go with a comp xtreme energy cam similar size or a comp magnum cam. You will get a little lopey idle but still get good vacuum. If all else fails get the comp thumpr flat tappet cam but the previous ones will give you better horsepower and torque. It will give you a nice choppy idle and not be too much problems. If you go with anything bigger expect some carb tunning headaches.
Eric
I guess with a manual trans, good gear and a light car I've never been afraid of to radical. The only cam that sounds better than a Z 60 is an L-88. JMO
ok thank you very much i think i will try this lunati good spec
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
