need help for choosing a cam - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-23-2008, 05:44 PM
F-BIRD'88's Avatar
Yada Yada Yada
Originally Posted by chevrolet327
f bird 88 my gear 4 10 the valve spring are z 28 style suppose to 550 lift?
Well the net lift with lash .016" is .514" on the exhaust side. (1.5:1 rocker)
If your valvetrain will handle that, you'd find that cam will really wakes up your 327. If not, a simple valve spring swap and maybe some spring seat shims to dial in the seat and open pressures.
Worth a call to Lunati. They'll help you with the details.
Needs to be degreed in for best results. I like to break in flat tappet cams using reduced spring pressure for the first bit of running time. (remove shims and or use old stock springs) Then change springs or add shims as required for correct installed height, change the oil and reset the valve lash and you're good to go.
A ZDDP anti wear additive like GM EOS is a good idea.
I think you'll really like that cam in your 327.
  #17 (permalink)
Old 08-23-2008, 06:59 PM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
ok thank you very much i think i will try this lunati good spec
If you do not want to register, fill this field only and the name will be used as user name for your post.
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 10:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
