need help for choosing a cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2008, 07:15 PM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
ok my set up is 327 11-1 domed piston camel hump fully ported aftermarket rod
performer rpm intake manual transmission. the problem is the cam i have is a summit 1105 cam 224/234 duration and 465/488 lift the cam run very well but idle is like stock engine . im looking for cam with similar spec but very rough idle
can a put more agressive cam on this little 327
Old 08-22-2008, 07:30 PM
DeathRattle's Avatar
Some Punk Kid
Whats the LSA on the summit cam?
Old 08-22-2008, 07:32 PM
114 lsa i need 108
Old 08-22-2008, 07:35 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
A great old school radical cam is the Isky Z-60 grind.
Old 08-22-2008, 07:36 PM
Some Punk Kid
110 should work well for what you want comp cams magnum 270 should give you what you want it sounded very nice in my 357.
Old 08-22-2008, 07:37 PM
do you have more spec this z-60 cam
Old 08-22-2008, 07:38 PM
Go with a comp xtreme energy cam similar size or a comp magnum cam. You will get a little lopey idle but still get good vacuum. If all else fails get the comp thumpr flat tappet cam but the previous ones will give you better horsepower and torque. It will give you a nice choppy idle and not be too much problems. If you go with anything bigger expect some carb tunning headaches.
Eric
Old 08-22-2008, 07:42 PM
1930u's Avatar
Here you go...Isky z-60 solid 292/292 adv. 259/259 @.050 .548/.548 108CL
Old 08-22-2008, 07:58 PM
the z 60 is too much radical
Old 08-22-2008, 08:00 PM
the max i will go is 525 lift 240 dur
Old 08-22-2008, 08:34 PM
NAIRB's Avatar
Use a Comp 280 mag. It's tried and true, and it has a rumpety idle while still being streetable.
Old 08-23-2008, 02:41 AM
JeffB's Avatar
You could do it the cheap way,put a manual choke on it and pull it out a ways and it will sound choppy then push it in when you want it to run decent.
Old 08-23-2008, 07:33 AM
1930u's Avatar
I guess with a manual trans, good gear and a light car I've never been afraid of to radical. The only cam that sounds better than a Z 60 is an L-88. JMO
Old 08-23-2008, 06:11 PM
f bird 88 my gear 4 10 the valve spring are z 28 style suppose to 550 lift?
Old 08-23-2008, 07:59 PM
ok thank you very much i think i will try this lunati good spec
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 11:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 11:17 PM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 12:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 12:51 PM
