Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help choosing a cam. (350 SBC)
Old 02-17-2011, 01:10 AM
FastOrange's Avatar
FastOrange FastOrange is offline
hi guys, need your help, i should have done this the first time, but i didnt and ended up going for the Comp Mutha Thumpr, which i now realize is a MISTAKE!
anyways, im looking for a cam that is .480 lift (I did get away with the .489 lift, but its damn close) or under cause of my vortec's and is Flat Tappet.
Engine is in a 1994 C1500, Regular cab, short box, currently a Weekend Warrior type of deal, going to be drag racing it this year.
Specs:
1988 TBI 350, Stock Bottom End, 4-Bolt Main.
1997 Vortec 906 Heads
Comp Valve Springs, Retainers, Locks (Need to upgrade to beehives to run higher lift.)
Comp Pushrods
Edelbrock RPM Performer
1" Open Spacer
Holley 670CFM Street Avenger
MSD StreetFire with upgraded MSD Coil and MSD Module
Taylor 8mm Spiro Pros
NGK TR55 Plugs
Cloyes Double Roller Chain
Flowtech Headers
THM400 Stock
Shift Kit
3500 Convertor
10-bolt Rear
PowerTrax Locker
4.10's
Any Ideas guys?
Im currently looking at a Lunati 292 Bracket Master II.
