Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help choosing a cam. SBC 350
Old 10-10-2012, 10:03 AM
bygddy bygddy is offline
Originally Posted by hcompton View Post
You will need to do a search for a compression ratio calculator on google. FYI chevy 350 is 4.0 bore and 3.48 stroke stock.
Big car with gear and good intake/exhuast for low compression I would go with the edelbrock performer or the performer rpm if you find out you have high enough compression to run it.
Edelbrock could help you get the setup with the right stuff. Just give them a call.
You have got a massive amount of choices for cams. Edelbrock has shorten this down to a few good choices. Makes the selection easier.
Or listen to people who have done it, built it, cruised it, raced it....as opposed to calling someone with a product to peddle.....that's the drawback to calling edelbrock, sure, you can buy a top end package, which is exactly what their going to reccomend, or you can mix and match, spend time and effort, not money, on something you did yourself with a little help from "real" people who understand budget and reality.....
The Following User Says Thank You to bygddy For This Useful Post:
Camaro_Nut2001 (12-04-2012)
