Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help choosing a cam. SBC 350
Old 10-10-2012, 12:09 PM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Senior Curmudgeon
Wiki Edits: 326
Originally Posted by grandslam1991 View Post
I did a compression test the other day, all cyclinders were in the range of 160-170 PSI, although not sure of the compression ratio. hope that helps ill try get compression ratio numbers.
Crane Cams |
