Need help choosing heads. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-13-2010, 03:28 PM
chevydragster83's Avatar
yeah I really just didnt know what was considered street drivin be cause like I said i wont be in town with it. but you huys have helped me understand more what I need.
I need your opinion on the 180cc rhs pro action iron heads VS the edelbrock 185cc performer RPM aluminum heads. There pretty close to the same price range as far as I can tell. which would you recommend out of the two? are the rhs iron heads that much better to pay the same as the edelbrocks being aluminum?
  #17 (permalink)
Old 04-13-2010, 03:32 PM
yeah I really just didnt know what was considered street drivin be cause like I said i wont be in town with it. but you guys have helped me understand more what I need.
  #18 (permalink)
Old 04-13-2010, 04:03 PM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
RHS is one of the leaders in iron head manufacturers, those would be the ones i would go after, i have never liked edelbrock heads although i have seen that they have stepped up their game here lately. the way i would look at it is look at the price of any good iron head and you will see that they are all about 900-1000 dollars, then look up any good alm head and you will see that they are much closer to 1500+, and in my opinion the only exception to this rule would be the Brodix IK heads, they are alm and cost about 1000-1200, but i believe that they are made of a lower quality alm than the rest of their heads
  #19 (permalink)
Old 04-14-2010, 11:00 AM
Ok if I went with the 180cc RHS pro action iron heads I have a lunati bracket master II cam 230/230 292/292 480 lift how would that cam perform with thoughs heads? if it would do good I would like to use it because I already have it, but if not I will go ahead and get a new one.
  #20 (permalink)
Old 04-14-2010, 03:22 PM
my87Z's Avatar
it would work great, just throw in a set of gears and a decent stall and you're good to go. those heads can handle more cam than that if they need to
  #21 (permalink)
Old 04-14-2010, 04:27 PM
ok I have 4:10 gears and I'm going to get a stall converter. what stall would you recommend?
  #22 (permalink)
Old 04-14-2010, 06:32 PM
my87Z's Avatar
i recomend a 2500-2800 stall
  #23 (permalink)
Old 04-14-2010, 08:44 PM
This may be a dumb question, but I am planing on getting all of this work done by a mechanic.Would it be ok to use my stock converter for a little while? Then I can get a new one and install it my self to save some labor cost.
  #24 (permalink)
Old 04-16-2010, 10:50 PM
how far from 400 hp do you think i would be with this set up?
Help finding the right heads for my 383 stroker pittbull7934 Engine 33 07-07-2009 11:11 PM
HiPo heads RJL Engine 16 06-29-2009 09:18 PM
Aluminum SBC Heads SierraClassic400sbc Engine 16 03-28-2009 03:53 PM
need help with choosing the right combination.. weaz4200 Engine 55 10-29-2008 12:58 PM
Need Help Choosing Heads DMAYS@TRIAD.RR.COM Engine 1 11-26-2006 06:54 AM
