Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with choosing the right combination..
Old 09-27-2008, 10:05 PM
Nothing's Easy Nothing's Easy is offline
Have a look at the Air Flow Research 180's. They cost a little more but they're pretty much the best you can do for a street/strip 350. Comp Cams recommended a single pattern 08-430-08 or 08-450-8 roller cam to go with the heads since the exhaust port on the heads flow well enough they don't need more exhaust lift or duration.
