Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with choosing the right combination..
Old 09-28-2008, 06:21 AM
Nothing's Easy Nothing's Easy is offline
Originally Posted by weaz4200
ive been looking around a thought about getting this list of parts....the 350 block i mentioned before...with these heads ( and with this cam ( ..what do you think. also how do i calculate the compression ratio with this setup?
I forgot to mention the Comp Cams guy recommended to install the 08-450-08 cam 4 degrees advanced (its just an advance keyway on most after market timing chains). Its supposed to give the cam a better bottom end for cars without the recommended gears or 2500 stall converter.
