Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help cleaning up a paint job.
Old 06-16-2013, 03:19 PM
glhx glhx is offline
The Beemer is a 2002 330ci
I've got all the paint according no to the codes. Now I just need to figure out how to repair it. Are you saying I should sand it all down and re paint. What else would you use besides base clear.
I want to learn blending. I have found very little on how to fix a chip in the paint.
One video showed back sanding and feathering with half inch between coats. Then filling with primer. Then spraying paint on it and clearing the whole panel after scuffing with prep paste.
With that primer still smelling wet it leads me to believe the primer should be sanded out.
One of my problems is. If that's doing it in that spot. What's the rest of the paint look like. It's my daily driver so I do need it back on the road
