need help with clear coat & single-stage - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 10:58 PM
when applying a coat of clear coat over single stage how long after do i wait to apply clear?? and do i have to scuff the single stage so the clear would stick??cuz im going to b adding pearls to the clear
Old 03-08-2010, 02:49 AM
Kleer
is ur paint metalic?
I know with single stage u can cut and rub matalic,
but with base and clear ur not supposed to sand metalic.
U pose a good question but I honestly would not clear
over single stage. As it allready has uv protection. But then
ur want a pearl. I would go with a base coat/ top coat if ur
going to invest in clear n pearl. Make sure there compatible.
The best way to go about it is with let down panels, so u can
catalog ur mixtures of pearl and clear over pearl. This is really
handy when using Kandy so u don't get uneven coverage.
Unless u got money to piss away on paint . Hope this helps you .
At the very least ask a auto paint supplier about compatability
but I'm guessing u got ur eye on that shelf at autozone.
Cheap paints are exactly that... But with the right prep
I've seen rattle can jobs that turned out ... Well maybee not
but what's the worst that can happen sand it of again.
Or strip it somehow.
Old 03-08-2010, 07:14 AM
deadbodyman's Avatar
Wiki Edits: 11
use a bc/cc with pearls,candies and metalics...its less work and looks much better theres no good reason to use a SS for a base...If its already been SS sand it back down with 600 and put the pearl in an intermix clear (clear base coat) then clear (two coats) it'll come out more uniform and look professional.depending on the kind of SS three days to a week should be enough cure time, if its an enamal longer...thats another reason we use bc/cc
Old 03-08-2010, 11:40 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I wait overnight to clear single stage urethane, (I don't know about enamel)
with metallics, you run the risk of the metallic mottleing if you rush it.
I've done that. It will disturb it and make it look uneven, sometimes
like stripes. I have gotten by with just 3 hours but overnight is much safer.
I don't scuff or sand either, no reason too within 24 hrs.
I have to say, urethane color with a clear coat is the strongest paint
I have ever used. I did my daily driver that way more than 3 yrs ago
and It still hasn't gotten the first chip. It's been unbelievable
Help with PPG Deltron base coat paint and clear coat Please smithkustoms Body - Exterior 31 01-12-2012 07:43 AM
Some Paint Questions (sanding clear coat etc.) FiefSS Body - Exterior 4 01-10-2010 08:43 PM
cosmichrome drchip Hotrodders' Lounge 19 12-28-2009 05:33 PM
Air Compressor for Automotive Painting m1helmethead Garage - Tools 34 12-26-2009 07:36 PM
clear coating single stage paint sbc307 Body - Exterior 20 10-27-2009 05:21 AM
