-   -   Need help with coil springs (http://www.hotrodders.com/forum/need-help-coil-springs-225556.html)
74novass 10-30-2012 07:41 AM
Hi everybody, i have a 74 nova ss. My front coil springs are sagging , i want to lift the front back up to the regular height it should b. i went to autozone to buy coil springs, they have have a option of with a/c or without. Wich should i get the with a/c or without? I just want the front to b up like it normally should. My brother has a 70 nova with new springs in front and it sits nice, and my friend has a 71 pontiac ventura that also sits nice up front. Just wanted to know what should i get, i also have a small block like they do. Thanks everybody
69 widetrack 10-30-2012 08:39 AM
First question, do you have A/C or not...Get the replacement springs that recommended by the manufacturer for your car...I did a 72 Nova 4 years ago and the new after market springs (AC Delco) that we installed gave me a higher than factory ride height....I replaced them with Moog springs and all was well...This is a recount of what happened to me in the past...I am not suggesting that Moog is the only way to go, just do your homework before purchasing...I guess that's what your doing by posting here.
74novass 10-30-2012 08:54 AM
Hi, no i have no a/c just figured the a/c springs might b stronger and keep the front somewhar level , thanks for responding also
69 widetrack 10-30-2012 08:58 AM
Stick with the Non A/C spring to ensure proper ride height, you'll be happier in the long run...I'm assuming that the drive train is stock, ie. engine?
poncho62 10-30-2012 08:59 AM
Ask your brother which springs he used. Probably the non A\C springs are the way to go. I bought an el Camino one time, it sat way too high. Probably A/C springs in it. I ended up cutting 1/2 coil out of them.
74novass 10-30-2012 09:07 AM
Hi yes 350 , top proline heads comp 292, je pistons, hooker headers, vic jr , 750 dp and turbo 350 tci st fighter converter 373 gears, yea im gonna stick with the non a/c springs, plus there cheaper. I just want a factory looking height up front. Thanks for ur help
69 widetrack 10-30-2012 09:17 AM
Good call, my buddy poncho 62 and I would not steer you wrong, with the information you just listed...Non A/C springs and all your camping experiences will be happy.
Ray
74novass 10-30-2012 09:26 AM
I thank u for your info, im going with the non a/c springs from either autozone, or advance auto parts
