Need help with computer controlled SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2009, 04:01 PM
I'm sure most of you know how I feel, You see I have this in my blood and sometimes it makes you do things that you regret. I just bought a 5 liter SBC (1988) as it was carburated I didnt realize that it is a computer controlled engine. Now the wires were cut and I have no computer so I want to have it run without the computer. My questions are what does it take to get this done on the cheap. Will the distributor and carburator work without the computor or am I going to have to buy new ones? If so will an eariler model distributor and carb. work?
Thanks in advance!
Mike
Old 08-13-2009, 05:15 PM
Saitek5678
saitek5678
Need more info on what you are doing
Old 08-13-2009, 06:31 PM
Well I don't know what all you have but to start off with for ignition a non computer type HEI distributor would be a start but if your transmission has computer controlls on it then you will need more then just that to start off with. Just as the guy stated earlier give more info what tranny are you going to use with the motor etc.
Eric
Old 08-13-2009, 06:40 PM
Saitek5678
saitek5678
what are you trying to do? year, make, model? are you tryin to put a engine in? If so use all the outer parts from your old engine and bolt them on to the new one, intake, exhaust, all of it , All you need from the new engine is the basic long block. GOOD GOD MAN!!
Long Awaited 400 SBC Dyno Results Mad Maggot Engine 19 10-14-2011 07:29 PM
Computer controlled HEI TroyBoy Engine 16 03-13-2009 07:56 AM
What Kind Of Cam is This? mightycarlo10 Engine 6 05-11-2008 08:40 AM
Computer Q-jet (CCC) on a non-computer car 87442lover Engine 2 10-28-2004 11:05 PM
truck 700 R4 computer controlled?? Ridr Transmission - Rearend 2 07-09-2003 04:53 PM
