need help connecting shift linkage to turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2010, 08:39 PM
I've certainly learned that my memory is very poor. I felt confident that I could remember quite easily how everything would go back together and wouldn't need any pictures to help remind me but of course I was wrong.
I am trying to hook everything back up on my father/daughter 1977 camaro project car and can't get the shift linkage re-attached.
I thought that the bracket that holds the cable from the shift selector mounted to the oil pan using the second and third holes starting at the front left corner. However, when I do this, the cable isn't long enough to reach the connection point on the attachment point coming out of the tranny.
Could someone please post pictures of a similar setup please? As always, I appreciate everyones assistance.
ID:	45335   Click image for larger version
Old 04-23-2010, 08:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you have the linkage on the shift shaft upside down
ericnova72's Avatar
More for Less Racer
Your memory of the cable bracket sounds correct, the lever on the trans is mounted wrong side up from the looks of it, lever attachment point to the cable should hang down below the pan rail.
Old 04-23-2010, 08:50 PM
I was wondering about that. The gentleman that rebuilt the tranny for me said it had been a couple of years since doing one. Is it as simple as taking that nut off and turning it 180 degrees or will I have to take the pan off?
Old 04-23-2010, 09:04 PM
ericnova72's Avatar
More for Less Racer
Remove the nut, reorient the linkage lever, replace the nut. You don't have to get into the pan for this
Old 04-23-2010, 09:07 PM
thanx a bunch guys for the speedy replies
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Shift Problems with a 350 Turbo Transmission 84' SS Guy Transmission - Rearend 25 07-17-2008 12:00 AM
Turbo 350 dropping out of 3rd gear aoz28 Transmission - Rearend 1 06-18-2008 08:45 PM
Turbo 350 & 550 HP BB Chevy leejoy Transmission - Rearend 4 12-06-2007 09:56 PM
How many times does a turbo 350 shift? batman09 Transmission - Rearend 8 10-03-2004 06:44 PM
