need help on converting column shift too floor shift . - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2005, 08:14 PM
i have a 69 chevelle that was originally a column shift and i installed a b&m floor shifter how can i hook up the back up lights and the neutral safety switch. my shifter has the switches for hooking up these accesories.and i have tryed too jump the wires off of the existing switch on the column but i have had no success.and i have checked the wires for voltage and there isnt any .they worked fine when the column shift was still installed i have no blown fuses any suggestions would be helpful.
Old 11-29-2005, 08:29 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Locate your OLD NS and BU switches and mark the wires as such.
On the NS switch, put a meter on either wire, and ground set for V X 50 or autorange, then *-->Hit the starter<--*, It should go to 12 volts in the "Start" Position.
If not try the same on the other wire..If that does, extend those wires to your new location on the B&M linkage.
On the Backup lamps, turn the key on and just jumper them across both wires, The lamps should light..If so extend those to the BU location on the B&M Linkage.
Neutral Safety Switch GM type
Doc
Column shift on a 50 Hudson?! jsrail Transmission - Rearend 3 11-02-2005 08:08 AM
column to floor shift conversion cantspel Transmission - Rearend 14 12-28-2004 08:51 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
column shift into 54 chev PU DV8 Suspension - Brakes - Steering 6 04-22-2004 08:29 PM
GM column gear shift knob 54 Chevy Interior 1 09-08-2003 08:03 AM
