Need HELP...courtesy lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2009, 07:17 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Being a total wiring moron, I can't get the courtesy light circuit working.
I'm using Ford (2 conductor) door switches and single wire bulb assemblies (the case prongs ground to the dash).
I wired the (+) side to the fuse-block, to the door switch, to the driver bulb, to the passenger door switch, to the passenger bulb.
I wired the (-) side to chassis, to the driver switch, to the passenger switch.
When I put 12v to the circuit I blow the bulbs.
I'm a total idiot, I can't do this (simple?) circuit.
Any help would be appreciated.
Thanks,
Bob
Old 10-11-2009, 08:19 PM
BOBCRMAN@aol.com's Avatar
Hot should go only to the bulb. Then from the bulb, thru the switch to ground. 1 hot wire in and the negative side of the bulb holder out to the grounded switch= light.
Old 10-11-2009, 08:36 PM
AngliaBob's Avatar
Bob,
I am running 1 hot lead from source to (d)switch to (d)bulb to (p)switch to (p)bulb.
The negative is from the chassis to (d)switch to (p)switch.
Thanks,
Bob
Ps:bulb holder is self-grounding.
Old 10-11-2009, 08:55 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
This may be a stupid question, but is the power wire going to the center wire in the bulb reciprocal?
What bulb number are you using? It may not be handling the amp draw.
Old 10-11-2009, 09:30 PM
Joe G's Avatar
Bob,
If you are blowing bulbs, it must be because you are using 6 volt bulbs instead of 12 V bulbs. If you are blowing FUSES, it is because there is a short circuit - as in power flows through the switches directly to ground, without having to go through the bulbs.
Typically, the courtesy lights are not wired independently of each other. They should both come on regardless of which door is opened.
It is common in older Ford products to switch the positive side of the courtesy light circuit. Most, if not all GM courtesy light circuits are wired differently.
From what I understand, based on the components you have described, I would wire them as follows:
One important note: If you are using a GM style headlight switch (like the ones that come in all the universal wiring kits), you cannot connect it to this circuit without either using a relay or changing the bulbs, sockets, and the way it is wired.
Hope this helps...
Joe G.
Old 10-12-2009, 12:33 PM
Just to add a little to Joe G.'s explanation.
Many standard door switches are designed to be screwed into the grounded door frame. When the door is opened, the spring loaded pin moves out and connects the single wire to ground through the door frame.
The other side of the courtesy bulbs are connected to constant 12 volts power, so when the path to ground is completed through the door pin switch, the lights come on.
If your Ford is designed to use the opposite wiring scheme, which would be switching the 12 volts on and off, then you will certainly blow fuses if you connect that wire to a grounded door switch.
Bruce
Old 10-12-2009, 03:42 PM
AngliaBob's Avatar
All...thank you very much...
Joe G...You are the man...Hooked it up like your diagram and it works perfect...
Thanks again everyone
GM courtesy lights 78 monte Electrical 13 11-25-2009 06:48 PM
Having problems with the tail lights... HammerGVette Electrical 3 04-17-2007 02:06 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 07:51 PM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 04:20 PM
Courtesy lights won't turn off carnutjoef Electrical 3 06-19-2002 02:42 PM
