Need help with crank gear. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2008, 01:15 PM
chewyscool's Avatar
Big Block 454
I'm putting back together my small block and I need to remove the timing gear from the crank to install the new one. What is the best way to get it off the crank? Damper has been removed. Thanks for any advice or help.
Old 05-11-2008, 01:33 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
A two arm puller works best, but you can start removing it with a crows foot pry bar and then a punch and hammer.
drive gear problems-th350 billsnogo Transmission - Rearend 3 06-18-2007 07:07 PM
GEAR DRIVE = DAMPER PROBLEM bullheimer Engine 5 07-06-2006 12:09 PM
forged crank question Ratoflic Engine 2 04-18-2006 04:50 AM
Edelbrock Gear Drive!~!~ Help!! boneyard Buick Engine 1 05-27-2005 03:59 AM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 03:56 PM
