Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with cut&polish
Old 08-10-2012, 09:49 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
If you have cut the clear with progressivly less paper (1000-1500-2000 then 2500 grit) then use a buffer and some less than aggresive buffing compound. I prefer not using a wool pad as they are far too aggresive for a novice to use. The foam buffing pads are much more forgiving and give just as good or better results than wool pads IMO.
Vince
