Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with cut&polish
Old 08-10-2012, 11:16 AM
tech69 tech69 is offline
put up or shut up
What you have to do to utilize the advantage of wool while doing swirl free work is just compound it with a foam pad too. Same with super cut compound. I don't use it but when I did I just went after with a less aggressive compound. It's just trading marks and getting less aggressive as you go so with that said, a wool can't do you no wrong unless the technique isn't right.
Going by some people's beliefs on wool around here...
wouldn't the sand scratch itself be a no-no too then, being a wool pad swirl is far less aggressive then the scratch to begin with?
With all that said, we have our own ways to get the job done and nobody is wrong as long it's within reason
