need help deciding on using 700R or turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2006, 08:31 PM
Last journal entry: dash mods
I have a 38 Chev slowly going together, 350 sbc 8.5/1 compression, 204/214 cam, Edelbrock manifold, Holley 600 and 10 bolt GM rear end with a posi 2:73 gear.Chassis is done and I'm putting in mounts.Everyone says use the turbo 350,but I want to use a stage 1 700R4.My problem is I do not know if the dif gear ratio is too high to use a 700R.Will I be doing 90 at idle speed?Can I pull a gear that tall?.The 700 should get off the line easier tho. Which trany???
Thanks Cisco.
Old 09-06-2006, 09:38 PM
jakeshoe's Avatar
I would probably go with a 700 in this case, although you would be cruising pretty good with those rear gears and OD...
As mild as your motor is, if you properly setup the lockup converter, it will be fine in OD, even at very low rpms, say 1600-1800.
Old 09-06-2006, 09:53 PM
Any ideas on rpms at 60 mph with a 28 to 29'' tall tire with a 700R and a 2:73 axle? And yes I want mpg out of this car, wanna drive it and it's all rural or highway here. thanks Cisco
Old 09-06-2006, 10:42 PM
jakeshoe's Avatar
Looks like about 1400 rpm at 60 mph. 1600 at 70 mph.
Old 09-06-2006, 11:27 PM
crap, can I cruise that low without jerking the U joints out? Guess I'll have an excuse to drive 80. ;O) Cisco
Old 09-06-2006, 11:30 PM
how did you figure out the rpm? Cisco
Old 09-06-2006, 11:41 PM
jakeshoe's Avatar
AS mild as your combo will be, it will cruise fine at 1600 rpm, however you will want the converter to unlock under any load conditions, this will raise rpm by about 300-400 rpms usually and that will put you where it needs to be at light load.
You will want to use a vacuum switch for this.
I would use a 4th gear lockup with a vacuum switch, see how that works and them possible a speed sensitive setup added in like B&M's lockup kit.
I used a 350 Chevy in a 72 Camaro with a 6 speed for a couple of weeks, it would run along OK at 1600 rpm with a cam very similar to yours.
You will also want a very good low speed carb or EFI. A Quadrajet would work well.
I figured RPM using a calculator I have on an auto program I use.
You can find calculators online to do this, some are downloadable, others you use online. You could make a spreadsheet to calculate it for you.
Tire size, rear ratio, trans drive ratio, mph, and engine rpm.
Old 09-06-2006, 11:54 PM
Thanks for your time Jake !! Is a Holley 4160 speed sensitive? Cisco
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
350 or 383 for a Turbo application? Siggy_Freud Engine 15 07-23-2006 10:51 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350 in a 66 ChevyII sledge57 Transmission - Rearend 1 10-06-2003 04:54 AM
turbo 350?? +nub+ Engine 5 10-05-2003 09:22 PM
