Need help determining wheel tire size - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 10:59 AM
Kustom Painter
Currently I have 185X78-14 on front and a 255x55-15 on the back of my 39 Chevy truck. I need to lift the front due to low clearance and do not want to do any re-welding of the front suspension to raise it.
What would be the best tire set up to raise the front up about 2"?
Would 16 inchers work and look good all around.
Hope so one can help.
Thanks Lungs
Old 03-31-2012, 12:47 PM
goldenrog
almost 2" taller
185/75R14 24.9 tall 7.3 wide
New 215/75R14 26.7 tall 8.5 wide this will only give you about an inch lift
New 195/75R16 27.5 tall 7.7 wide
16 might be a better choice as it's closer to width of whats on it now
what is the best tire size for a wheel size? wave1957 Hotrodding Basics 16 11-30-2011 06:58 PM
Tire size vs. wheel size Ratdoggy General Rodding Tech 7 11-11-2009 07:00 AM
Wheel and tire size help BMM General Rodding Tech 3 09-01-2006 07:42 PM
wheel and tire size for 38 ford stoke46 Body - Exterior 1 02-05-2006 12:30 PM
Tire wheel size 78 monte General Rodding Tech 1 08-29-2003 06:29 PM
