need help to disengage locking mech in 70 cuda steering column. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 07:47 AM
Hi, I have a 1970 cuda with an A/T and the original car had the automatic shifter on the column. The last PO put in a floor shifter in and still left the column shifter hooked up. I am trying to get rid of the
shifter on the column but don't know what to do to disengage it and still make the car start and function. I can not take the key out if the floor shifter is not in park? Any help would be appreciated.
Old 07-15-2012, 03:39 PM
spinn's Avatar
Remove the column linkage and use the floor. Leave the column position in park and remove handle. The key push release ring is deep behind and do not know a way around it. Other than lock it in release position. That ring has nothing to do with PRNDL location. in the 80's my 70 cuda had a floor shifter with the little knob left from the shifter. I left it in park.
My 71 currrent cuda is a 4 speed and has factory column. You can find them in auctions.
I have a floor console and auto shifter with linkage complete up in the attic. Sounds like you need the column.
Old 07-17-2012, 07:07 AM
Thank you, I will try this and yes I agree with you that I need a new column......
How to wire column shift light in flaming river steering column firstgear Electrical 6 03-02-2012 10:14 PM
Locking Mech and vac advance on HEI issues maxpower_454 Engine 5 05-20-2010 05:46 PM
Steering Locking Up On Turns 10mikeymike Suspension - Brakes - Steering 1 08-02-2008 06:40 PM
Steering is locking up 70bird Suspension - Brakes - Steering 6 09-28-2005 02:18 PM
'71 'Cuda steering.....? SJFast Suspension - Brakes - Steering 0 07-26-2002 04:20 AM
