Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with distributor
Old 09-03-2012, 05:41 PM
67Mustang Al.'s Avatar
67Mustang Al. 67Mustang Al. is offline
Originally Posted by T-bucket23 View Post
This is true of any ignition that uses a coil. As revs go up you have less time to build the field charge in the coil. The biggest issue with points is they become unstable at higher rpm and can bounce or float. The electronic distributors either use optical or hall effect sensors and they are just as stable at 8K rpm as the are at 800 rpm. Nothing mechanical to bounce around.
A good HEI is more than most street engines will require.
Years back i found a CDI diy kit with an output of 80,000volts that ran in conjunction with points ignition. I put twin kits on a Z900 Kawasaki which i drag raced. Problem was there was voltage going to the plugs sometimes but mostly it was jumping out at the frame and handlebars.
Electrifrying ride.
The Following User Says Thank You to 67Mustang Al. For This Useful Post:
Live Action! (09-04-2012)
