Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with distributor
Old 09-03-2012, 05:47 PM
cdminter59 cdminter59 is offline
Originally Posted by Live Action! View Post
I have a 383 stroker with a mc1988 cam in my 73 impala, all parts have been up graded except my stock distributor; which was new thats why I used it also has points and dwell at 30. I have about 375 horse and 400 ftp torque. Was built for bottem end to mid range. I seem to get good mid and top but dont think the bottem end isn't were it should be.
1. Do I need to up grade to a Hei or Msd distributor and how many volts?
2.I have it set at base time 12 degrees Atdc.
3. Problem still running alittle rich, I have a 600cfm edelbrock turned out 1 3/4 factory set, also turned it back 1/2 to see if it helped.
4. In park I have Ideal speed at 750, Please help try to fine tune it! Thanks
I am with Delawarebill I hope #2 is a misprint. If not try setting it to 12* BTDC and use a vacuum gauge hooked to a vacuum port on the intake manifold. Advance distributor for the highest vacuum reading then move it back 2-4 in./hg. If engine pings decrease until pinging stops. Also you can adjust idle screws on your carburetor to the highest readings.
The Following User Says Thank You to cdminter59 For This Useful Post:
Live Action! (09-04-2012)
