Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with distributor
Old 09-04-2012, 02:41 PM
Custom10's Avatar
Custom10 Custom10 is offline
my KARMA ran over my DOGMA
Last journal entry: SS
If you are in the market for an upgrade check this out
White Performance Detail Description
You just cant beat the value, they are easy to set up as well. Make sure you have firewall clearance. Lifetime warranty, 50 bucks, it is a no brainer.
Use it with this limiter plate, limit vacuum adv to 12-14 advance. The unit will add approx 20 deg vacuum advance out of the box, too much
Crane Cams 99619-1 - Crane Vacuum Timing Limiter Plates - Overview - SummitRacing.com
Try it at about 16-20 deg BTDC as the initial and 32-36 total. Use a simple 6/32 screw/nut with some lock tight to limit the mech advance on the HEI rotor plate, the hole is already drilled. The unit will have about 24 deg mechanical advance out of the box, too much.
Give it constant 12V from 15A fused 12 gage feed with toggle switch on dash or elsewhere within reach from driving position.
Have fun
The Following User Says Thank You to Custom10 For This Useful Post:
Live Action! (09-04-2012)
