Need help with distrubitor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 12:15 PM
Hey I'm new here & seems to have a lot of knowledgeable folks here,so I have a '72 nova w/ a 250 c.i.d. 6.But I have a h.e.i. from a 79 nova.One of the points on the cap was broke,so me & a buddy replaced the cap & now won't start!We've been trying to find the firing order for the cap also. It was also choking out @ 55-65 mph but now is doing it @ 35! Please someone help, this is my daily driver,Thanks
Old 03-22-2010, 06:24 PM
fast68's Avatar
likes chevy trucks & boobies
the firing order is cast on the intake manifold somewhere if you look around
set the engine to #1 TDC of compression stroke
see what tower on the cap the rotor is pointing at
this will be your #1 tower
now run the wires to each cylinder in the same number order around the cap startin at your #1 tower. same number order as the firing order cast on the intake manifold
fron of engine is #1
last one is #6
123456 front to back
is the cylinder numbers
Old 03-28-2010, 07:58 PM
Firing order is 1-5-3-6-2-4, clockwise looking down on the cap.
Distrubitor question 49fordp/u Engine 9 02-21-2008 06:34 PM
Grant Spalding Distrubitor jerryshop Hotrodders' Lounge 1 05-29-2002 01:21 AM
