Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with door alignment
Old 12-13-2012, 11:40 PM
MARTINSR MARTINSR is offline
It looks to me like the entire door is down. If you raise the door straight up the door will go "in" at the bottom where it angles in. Then out a tad at the top front as Henry pointed out will put it as close as it can be I am thinking. It looks like the bottom of the fender probably had a patch panel put on as the bottom is thicker than it should be, so there are a few things happening there that you may not be able to get better.
Remember that when you have angles like that at the bottom going straight up brings that surface IN as well as up.
