Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with door alignment
Old 12-14-2012, 01:21 AM
tech69 tech69 is offline
put up or shut up
good point. Just be sure to look at the top of the door compared to the top of the quarter/fender, especially the quarter cause it doesn't move. That will tell you for sure and that being flush is more of a priority than your rocker.
even if you don't do it yourself if you go in there and talk a good ball game and they won't try to get you for two hours of labor when it only takes 30 minutes.
