Good call Mike...the first thing I noticed was the smooth wheel well opening that led me to believing that the rear quarter had been replaced or at least worked. If that's the case then aligning the door becomes more of and issue than just adjustment. First question I would have is...has the rear quarter been replaced...Another question is was the quarter aligned to the door before it was welded in? The rear quarter needs to be installed with keeping the door in mind or gaps and adjustments are difficult. Even if you get a proper or acceptable gap, you may need to adjust other areas of the door to eliminate wind noise. So if you can tell us if the rear quarter has been replaced and if it was installed correctly we can help with the alignment issue.
Ray
