Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help with door alignment
Old 12-14-2012, 09:28 AM
Chevymon Chevymon is offline
This is really difficult to do without looking at it in person, because it all works together and one adjustment can cause a chain reaction. To see it in person one might spot the problem immediately and it may be quite simply that the door is just low in the back, as Brian said. Then the question is do you raise the whole door, pull the bottom back, or push the top forward. That is if the Chevelle has that much adjustment.
