Need Help with door panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2007, 10:20 AM
Last journal entry: Bringing home the 401 Nailhead
We are thinking of doing our door panels and have been experimenting with some methods. What we have done is cut a 1/8" panel the same size as the door panel. Onto this we glued a 1/8" pattern (flames). Sprayed glue on this and placed some scrap material over this then vacuumed it down. The problem we are having are the edges of the flame pattern are not very crisp. I suspect the material we chose is not stretchy (is that a word) enough to form over the sharp edges. What material do you suggest? Or should I bevel the edges of the pattern?
Old 12-23-2007, 10:25 AM
life is a temporary assignment
What glue are you using?And did you wait long enough before applying?
Old 12-23-2007, 11:05 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Lot of those I have seen were a fabric type material..I would ease the edges of the patterns just a bit to help the material pull down at that point. Might take a bit of bevel to allow the material to come down tight..Play with it a few more times until you get the drift of what is doable in your shop..Also for that sort of thing I would like an adhesive that will let the material flow a bit..not a contact adhesive..you may need to hold vacuum on the article for a bit longer to let the adhesive to set up..Rather than making your flame patterns out of a rigid material try some foam material as those need to be a bit soft for comfort..
All the tips I have for now..Maybe Dan has some more..
Sam
Old 12-23-2007, 12:09 PM
Just using 3M Super 77 for now. Thought of contact but decided to try this first. Found a piece of more forgiving material. Going to try that.
Old 12-23-2007, 12:12 PM
Sam
Never thought of using foam for the pattern. Will try that next. Thanks for the tip.
Old 12-23-2007, 12:17 PM
I don't find that stuff works to good.I use DAP Weldwood HHR Contact cement.I let it dry before putting it on.But don't press down on it, until you are ready.Are you will not move it.check in my album,I have some pics of a door panel without the cover on them.
Old 12-23-2007, 01:27 PM
302 Z28's Avatar
Do not ever use 3M #77 on interior work, it will not hold very well and eventually lets go.
Vince
Old 12-23-2007, 01:33 PM
Vince
Vince is 100% right!!!Don't use it.
Vince
It is free and just using it till I get my technique down pat.
Old 12-23-2007, 01:41 PM
It maybe free,But it could end up costing you in the end.Thats all we are trying to tell you.
Old 12-23-2007, 03:20 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You will not have good luck with 3-M 77. It just doesn't work for what you are trying to do. You need contact adhesive, or as soon as the vehicle gets warm, the 3-M 77 will fail. Because of the thickness of the materials used, like vinyl, leather, and Ultraleather, it is not easy to get crisp lines. Are you using closed cell foam for your designs? Whatever you use needs to be very firm to hold the shape.
Old 12-23-2007, 03:29 PM
Just using the 3M to test my technique/material and vacuum table. Was not planning to use it for the final product.
Right now I am using 1/8" hardboard for the patterns but plan on 1/8" ABS when I am ready for the real thing.
Wife wants to use something like a micro fleece for a subtle effect. I tried a piece of fleece and managed to get the effect she wants. I am concerned about contact cement bleeding through the fleece material so either will have to find a better glue or change my choice of material.
Thanks for all the help
Old 12-24-2007, 07:16 AM
Wiki Edits: 22
Yes, I understand that. My point is this: How will you know if you get the effect you're looking for if you don't use what will be used on the final product?
Old 12-24-2007, 09:42 AM
What Dan is saying is true.If you are going to practice use the right stuff.And if you do it right. Then you can use what you did.And it will last.Plus you are learning with the right stuff.And when you use the right stuff it will be alot easier for you.
Old 12-24-2007, 10:49 AM
Thanks for the advise - will give it a try after holidays.
