Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help with EFI to Carb Conversion
Old 02-28-2009, 10:34 PM
1969NovaSS's Avatar
1969NovaSS 1969NovaSS is offline
turbo lag......yeeeeehaaaaaaw
Is the crank sensor still hooked up to the factory wiring or does it just plug into the edelbrock box? The fuel pump will turn off if it doesn't pickup an rpm signal. I dont know how the conversion wires it but that may be your problem.
