Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help with EFI to Carb Conversion
Old 02-28-2009, 09:53 PM
Deeavi's Avatar
Deeavi Deeavi is offline
The crank sensor and the cam sensor are connected to the msd box.
I did not know that the pump requires a rpm signal. Thanks! There is a tach wire coming from the msd harness, but that is for the tachometer. Do you have any ideas for a work around?
