Need help with engine balancing
I decided a couple months ago that I would like to try and tackle the task of building an engine, even though I have no previous experience in the field (but I learn quickly). So I went with an SBC 350 (1970 2 bolt casting already machined 60 over), GM forged crank, and original heads 76cc. I bought the engine from a friend who ran it in his mud truck, and since I am quite familiar with his driving habits, I completely disassembled it to ensure I wouldn't run into any surprises in the future (even though the engine only had about 10K miles on a fresh rebuild). The cylinder walls and crankshaft were machined on the last rebuild and are still in perfect condition.
So I have all the parts I need to put the engine back together, and besides being completely clueless as to all the nuances experienced engine builders know how to handle, I feel fairly confident I can put it back together successfully. But...do I need to have the crankshaft looked at by a machine shop before reassembling the engine? It was just machined 10,000 miles ago (plus it's already machined to its max tolerances). Also, I noticed the harmonic balancer has five consecutive holes drilled in the back side of it which were not stock. The dampener is in pretty rough shape so I was thinking about replacing it, but will I have any problems since the new one won't have the custom holes? Any other tips on the build would be helpful as well. |
At the very least you should measure the cylinders and crankshaft journals while the engine is apart to verify that it doesn't need any machine work. Remember that at .060 over that block most likely won't be able to bored any further. It'd be in your best interest to know now that you've got good parts, rather than put it back together and find that it's deficient in one way or another and require another teardown.
As far as the balancer goes. He didn't by chance stroke it did he? If it's drilled because the engine is externally balanced and you put an internal balance balancer back on it'll be out of balance. It may not hurt to mock up one cylinder and measure the stroke. It'll be obvious because the 383 has a ~.250" longer stroke than a 350. |
To me, proper balancing is a no-brainer with most anything that I'd bother to rebuild in the first place. For even stock rebuilds, I have a machinist that I utilize who's geared towards performance builds and whom I trust completely. First, weight-matching of all parts is important, as is ensuring the rotating balance of any applicable components and finally the rotating assembly balancing as a whole. Proper and precise balancing will pay dividends in all ways, performance, reliability, overall efficiency and longevity. Don't cut corners here.... ever.
Thanks for the help
The pistons that I pulled out were flat top, and that's what I'm putting back in (with valve depressions). The crank casting number is 3941182, which is from a 68-76 350 at 3.48 stroke.
I'm having my pistons pressed in this week so I'll take the crank in to get looked at at the same time. Thanks for all the help! |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| ENGINE BALANCING | NAIRB | Engine | 14 | 09-06-2011 08:22 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Engine balancing mandatory....? | PairOf69's | Engine | 14 | 09-15-2007 07:27 AM |
| engine balancing question. | engineman302 | Engine | 4 | 05-27-2005 12:41 PM |
