Need help fast with 350. please answer! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-26-2010, 08:29 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by bubbahotep
I have a holley 750, 4160, that needs a good 10 seconds of cranking to start when hot. It was suggested on here that it's rich fuel in the carb from sitting and more air is needed so the 'wot' trick helps in my case. I wonder if you have a similar issue? Unfortunately, mashing the gas while cranking is also dumping gas form the accelerator pump into the carb causing a minor flooding issue.
I have to give about 1/4 throttle with my 1405 Edelbrock when the engine is hot . Not too bad . Just not used to it after having nothing but FI cars for the last 14 years .
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Centrifugal advance DENCOUCH Engine 7 05-07-2010 06:39 PM
350 idles too fast Aerotech Engine 14 03-12-2010 11:43 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
