Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help FAST!!!!!!!!!!
Old 06-24-2008, 05:59 PM
oldbogie oldbogie is offline
Originally Posted by millertime85
thanks.i got the block number and heres what pops up
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
He says its a SB 350 bored .40 over-makes it a 357 w/ high compression 305 heads.he said it was a 85 block.so i cant check the heads cause they will come back as a 305.but at least i know its not the stock 305 block.but how can i make sure it deff. is a 350 w/o a doubt???
You beat me too it, I just pulled MorTec into Excel did search and combine and dumped it to word, here it is for 350 blocks:
140029.....350...80-84...2
366245.....350...78-79...4...Bowtie
460703.....350.....78....4
3858618....350...68-76...2
3892657....350.....67....2...Camaro
3914678....350.....68....2
3932386....350.....69....2 or 4
3932388....350.....69....2 or 4
3956618....350.....69....2 or 4
3970014....350...70-76...2 or 4
6259425....350...69-76...2
10036033...350...........4...Goodwrench crate motor, 2-piece rear
10054727...350...86-up...2 or 4...one piece rear seal, some "Made in Canada"
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
10066038...350.....92....4...Goodwrench crate motor, 2-piece rear
10090511...350.....90....2...LT-5, ZR1 Vette, 375hp
10125327...350...92-up...2 or 4...Gen.II LT-1, reverse flow cooling
10125327...350...96-up...2 or 4...Gen.II LT-4, reverse flow cooling
10153558...350...91-92...4...LT-5, ZR1 Vette, 375hp
10199001...350...93-95...4...LT-5, ZR1 Vette, 405hp
10243878...305...96-98...2...Vortec truck, roller cam, one-piece rear seal
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
14010207...350...80-85...2 or 4
14010209...350...80-85...2 or 4
14011064...350...83......4
14011148...350...87-89.......Roller cam, one-piece rear seal
14016379...350...77-79...2 or 4
14079287...350...86-90.......Truck
14088526...350...87-89.......Roller cam, one-piece rear seal
14088548...350...86-88...2 or 4
14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
14101148...350...86-90...4...One-piece rear seal
The 010 is very good block, a lot of heavy duty and high performance engine were built by the factory on this block.
Bogie
