Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need Help FAST!!!!!!!!!!
Old 06-24-2008, 06:27 PM
oldbogie oldbogie is online now
Originally Posted by millertime85
So with all that i have found,everything is pointing to it being a 350 would you say???ill just have to pull the oil pan to check if its a 2 or 4 bolt.
Yep I'd say so. Back in the 1980s and even yet today the low buck way to overcome the large chamber low compression SMOG heads was to put a pair (usually reworked) of small chamber 305 heads on. Not as effective as todays heads, but with the right porting and some standard 350 size valves would work quite well.
Bogie
