Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help figuring out setting up rocker arm geometry
Old 07-13-2012, 04:02 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
valve train geometry from CompCams
COMP CamsŪ - Sorry...
advice, get rid of the 2 piece pushrod tips and get the one piece .
You will find them braking off and going down into the motor.
I had this happen to me along time ago along with some other's esp with lift over .500
Only grind at last resort & look at the obvious as that is the one that bites ya
Luv the smell of NITRO in the morning.
