Need help finding dics rotors... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2005, 09:00 AM
bg's Avatar
bg bg is offline
I have a 48 Chevy truck with a front nova clip not sure what year. It also has tubular A arms with an OEM spindle? What i am needing help is find a set of crossed drilled and slotted rotors to swap out.
I have had no luck in finding rotors just due to the fact i dont know the year of the front clip.
The GM oem rotor has a number on the inside of 81905 but has not been any help to me or my local parts store.
Does anybody know of a web site with detailed measurments of rotors....
ANY HELP !!!
Thanks
bg
Old 05-13-2005, 10:23 AM
302 Z28's Avatar
Give either Master Power Brakes, or Stainless Steel Brakes a call, they should help you out. They both have excellent web sites.
Vince
Old 05-13-2005, 10:32 AM
poncho62's Avatar
Wiki Edits: 5
I would put money on, that they are 73-79 rotors.........................68-72 disk brakes are kind of rare.
Old 05-13-2005, 10:33 AM
astroracer's Avatar
Nova's, Firebirds, Camaros, and many of the mid-size cars (g-bodies) all run the same brake rotors and bearings.
Pull out one of the bearings and have your parts house check the number. Cross reference it to any of the above vehicles and you'll be good to go (or stop)
Mark
Old 05-13-2005, 03:25 PM
bg's Avatar
bg bg is offline
i will try the bearing route... The bearing number is LM 57048 ... I will check that number at my parts store tommorrow.!!!
Thanks
Bg
Old 05-13-2005, 03:34 PM
astroracer's Avatar
You can do this stuff online as well. Go to carparts .com or a similar site and just start cross-referencing part numbers... You will be amazed at the re-use...
Mark
Old 05-13-2005, 06:04 PM
abstruse dutch uncle
If you are sure it is from a Nova and has stock spindles,
68-74 spindle and steering arm bolt together.
75-79 is integral.
I haven't seen any blemished... I mean, drilled/slotted discs for the 68-74, but there are plenty of complete upgrade kits with them... same parts as for 67-69 Camaro.
Old 05-13-2005, 07:07 PM
bg's Avatar
bg bg is offline
75-79 is integral.
YESGO,
The spindle and steer arm is all in one .... so you are saying it is a 75-79 year
I did some checking with the bearing number and did not have any luck after about an hour of checking at carparts.com??? I will keep trying thou.
Thanks
I will post a picture of the spindle soon...
Bg
Old 05-13-2005, 07:27 PM
bg's Avatar
bg bg is offline
Here is some pics.....
Here is some pics that might help you to help me
Thanks
bg
Name:	front spindle 5-13 007.jpg
ID:	4954   Click image for larger version
Name:	front spindle 5-13 008 (Small).jpg
ID:	4955   Click image for larger version
Name:	front spindle 5-13 006 (Small).jpg
Old 05-13-2005, 09:35 PM
I cant say for sure what it is, but I can say for sure it is NOT a stock spindle from a 68-74 Nova.
Old 05-13-2005, 11:47 PM
Those are drop spindles which will make them harder to ID then something factory. Are there any stampings at all on them? What size is the rotor?
It sure looks like g-body/s10 stuff to me...but can't be sure.
Rotors... bg Suspension - Brakes - Steering 4 04-25-2005 01:33 PM
blank rotors Mr Miyagi Suspension - Brakes - Steering 1 03-13-2005 08:28 PM
redrilled rotors 6speedwagon Suspension - Brakes - Steering 1 11-20-2004 08:44 PM
finding project cars wannabnewbie Hotrodding Basics 25 11-12-2004 05:10 PM
American Made Mustang II Rotors Sweet-34 Suspension - Brakes - Steering 2 05-17-2004 05:29 PM
