Need help finding fittings!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2008, 09:20 AM
Hi
I'm in a jam here and I hope someone can help. I'm relocating my MC from the firewall to the frame ,I don't have enough space between th MC & tranny for a normal 90* bend so what I need (and can't seem to find) are two 90* fittings and they are___1/2" x 20 IFM (inverted flare male) to 3/8" IFF (inverted flare female) and also 7/16" x 24 IFM to 38" IFF
Thanks
Old 02-12-2008, 09:51 AM
These might dodatrick
Check a site for Brakequip...they sell fittings, you probably won't need their minimum order so just look at the cat. and especially the banjo fittings...got me otta the same bind.
Goodluk, Randy
Old 02-12-2008, 11:36 AM
31 five window
Last journal entry: grill and rear end
I am not sure if they are the size you need but JEGS has banjo fittings,this is about the tightest 90 you can get. Hope this helps.
Old 02-12-2008, 11:55 AM
302 Z28's Avatar
Pure Choice Performance. If you order them from Jegs make sure they are not aluminum.
Vince
Old 02-12-2008, 12:20 PM
life is a temporary assignment
If you are going under the floor,you will need residual pressure valves,If you don't have them now.
Old 02-12-2008, 12:27 PM
I have them,Thanks
Old 02-12-2008, 12:28 PM
Old 02-12-2008, 12:31 PM
35chev/302gmc's Avatar
I found all the fitting,s I needed to plumb my brake and fuel systems at the local "hydraulic hose supply store"
1935 chevy,masters
Old 02-12-2008, 04:31 PM
HEY 302 Z28 Thanks!!!
I talked to the guy at PURE CHOICE PERFORMANCE and he's fixing me up with a banjo fitting, I don't know what I would do without the help of guys on this site someone ALWAYS has the answers!!!
Thanks again
Gary
brake line fittings 70Shorty Suspension - Brakes - Steering 3 01-23-2006 08:37 AM
Flared Fittings 37 Deg Vs 45 Deg leejoy Engine 9 01-02-2006 10:35 PM
tranny coolant line size for AN fittings guba_unus Transmission - Rearend 4 08-12-2005 06:14 PM
-AN fittings on transmission cooling lines jamnut Transmission - Rearend 3 07-14-2003 11:07 AM
th350 coolant line fittings fireball47 Transmission - Rearend 3 07-06-2003 12:05 PM
