need help finding hedders - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2011, 06:15 PM
57 3100 with 283 and stock steering box. Plenty of room on pass side but the hedders that came on truck have been flattened at least 50% closed to clear the box. Any one know of a pair that will fit? Another question why dont they make the hedders the same shape on both sides of eng. Most of the hedders I have seen, the shape of the pass side would work mint on the drivers side.
Old 09-22-2011, 07:07 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I take it you want full length, not clipsters or block huggers?
Old 09-23-2011, 04:46 AM
that is correct but if I cant find any will have to go to those
Old 09-23-2011, 05:11 PM
JeffB's Avatar
You will need something like these because of the steering box: http://www.ecklerstrucks.com/chevrol...1955-1987.html Some early Chevy Vans and Corvettes used a header with the tubes coming together across the flange like these but with longer primaries.
Old 09-28-2011, 06:17 PM
There are a number of options, depending on what your after. Block huggers and clipsters are fine for a mild street motor. Long tube headers are the better choice for high HP motor. Fenderwell headers could be used or you could by a kit and build your own.
I used block huggers that I modified on my last (2) hot rod builds, basically cutting off the collector and welding 2-1/2" mandrel bent tubes to get the collector flange down and away from the motor.
My Model A (355 SBC):
My Model T (5.0 HO SBF)
Hedman Elite hedders boss350 Engine 2 02-16-2007 01:03 PM
tri-y hedders for a hot 482 BBC dykkerdan Engine 9 12-22-2005 02:27 AM
edelbrock hedders for a 02 camaro grover805 Engine 1 12-12-2004 06:27 AM
66 Stang w/ 302 Hedders?!?!?! slavboy1 Engine 0 06-29-2004 08:16 PM
who makes hedders PropanePower Hotrodding Basics 7 04-01-2004 09:17 AM
